Disable/change alt+space?
Gryzor
Post by Gryzor » Apr 26th, ’18, 09:55
Hello!
Perhaps silly question and I'm missing something obvious, but how do I disable the module (?) that appears with alt+space, or change its hotkey? Because alt+space is used by other stuff on my PC...
Post by Tom » Apr 26th, ’18, 10:09
Go to Preferences/General/Shortcuts and change or remove Quick-find shortcut.
Gryzor
Post by Gryzor » Apr 26th, ’18, 10:12
Yup, indeed I missed that!
Thanks for the ultra fast reply :)
