Shortkeys query
RajDavda
Post by RajDavda » Apr 9th, ’18, 15:38
I've CTRL + ALT + N set to Run notepad3.exe in Shortkeys. Works as expected :)
Is there anyway to have choice of other editors to Run - similar to select strings in Text Expander?
E.g.
CTRL + ALT + N
Run
notepad3.exe
/notepad.exe
/Notepad++.exe
Thanks in advance.
Best Regards,
Raj
Post by Marko » Apr 9th, ’18, 16:39
Of course, you have it right. ;)
Shortcut: Ctrl + Alt + N
Type: Run
notepad3.exe
/notepad.exe
/Notepad++.exe
To improve visibility, you can add a description prefix to multiple selections, like this:
Firefox:: C:\Program Files (x86)\Mozilla Firefox\Firefox.exe
/FastKeys:: C:\Program Files\FastKeys\FastKeys.exe
RajDavda
Post by RajDavda » Apr 10th, ’18, 09:04
Thank you Marko,
I typed in manually everything (executable & path) and it worked. :)
I was trying to use Open button on right to pickup the notepad++ and it's path, but it replaced the original entry - namely noteapd3.exe. :(
Improving visibility is a bonus! 8-)
Thanks again.
Best Regards,
Raj
