I use Text Expander quite a lot for simple things in LaTeX.
However if i want to send curly brackets this doesnt work except when i select 'Send raw Text'.
I preferably dont want to use Send raw text so i can set a cursor location.
For example:
\begin{equation}\label{%Cursor%}
\end{equation}
results in:
\beginlabel
end
any solutions?
RMDoubleYou
Curly Brackets {} not working in a 'send'.
^ - Ctrl key,
! - Alt key,
+ - Shift key,
# - Win key.
This allows sending not only text but also other actions. To send those characters you need to enclose them in braces, like {^}, {!}, {+}, {#} or select Send Raw Text option. Braces needs to be enclosed in braces too, like {{}.
I shall give it a try, seems like its going to be a mess of curly brackets. But if it works i wont have to look at it
jup it works thans for the suggestion
