Is it possible to add a label to choices?
- BrittMalka
Hi, I'm new to FastKeys, and I'm not sure I can describe what I want... but I'll try.
I'm creating a macro that outputs a HTML form.
I want to be able to add certain list numbers into the form, like this: <input type="hidden" name="lists" value="1,2">
The values vary, and I would like to see a list of options, like 1 = General, 2 = Fiction, 3 = Nonfiction etc. I haven't been able to find anything about that. Can it be done?
Right-click on a command field to select HTML format. Than you can paste any html code and FastKeys will run it.
If you just need to send plain text, you can define your selections using Input Selection Forms macro (More/Macros...). To add a label to choices, use a description followed by description separator. The default description separator is "::" and can be changed in Preferences/Text Expander. Example:
Description1::Text1
Description2::Text2
- BrittMalka
I tried that. Or rather, I had it the other way round, I had
But now I tried your suggestion, but I couldn't make it work. It added both things to the form.
Yes, I only need text output.
This is what I have:
Type: Send
When I double-click on NVMList, I have
Type: Checkbox
Selection:
But the generated text gives me:
Text1::Description1
Text 2::Description2
Type: Send
<form method="post" target="_self" name="nvform" id="nvform" action="http://nvm.%SELECT_NVMDomain%.com/subscriber/optIn.php" autocomplete="off">
<input type="hidden" name="idGroup" value="1">
<input type="email" class="inputBox" name="email" value="">
<input type="text" class="inputBox" id="name" name="name" value="">
<input type="hidden" name="lists" value="%SELECT_NVMList%">
<input id="customSubField%INPUT_NVMSubField%" name="customSubField%INPUT_NVMSubField%[]" type="hidden" value="^v">
<input type="submit" class="nv_submit" id="nv_submit" value="Subscribe"></div>
</form>
Type: Checkbox
Selection:
General::1
Fiction::2
Nonfiction::3
Unknown::6
Change::20
<form method="post" target="_self" name="nvform" id="nvform" action="http://nvm.domain.com/subscriber/optIn.php" autocomplete="off">
<input type="hidden" name="lists" value="General::1,Fiction::2">
<input id="customSubField44" name="customSubField44[]" type="hidden" value="testagain">
</form>
Currently Radio and CheckBox controls do not support description labels. We may add this functionality in the next release. Can you use other control type instead?
- BrittMalka
Not for this one. But thanks for your reply.
I seem to be struggling with the same situation for check boxes. I am running Fastkeys 4.10 but no matter where I put "::" it outputs the whole line. I can't figure out what I'm doing wrong.
Sorry, currently Radio and CheckBox controls do not support description labels. We will add this functionality asap.
