Since updating from 3.13 to 3.16 on Windows 7 Pro 32-bit, I get the "ERROR. Some commands were stopped" message. The only module I have active is TextExpander, and I've made no change to my phrase file since the upgrade.
The message goes on to say, "Please check last edited commands and correct possible duplicate functions." I've checked the phrase file (the only text-expander abbreviations I use) and their are no duplicates or obvious syntax errors.
The message further provides a link for "Show error report," but clicking it does nothing. Is the report file actually stored somewhere? I couldn't find it in the Fastkeys program directory. Thanks!
Since updating to 3.16, getting "Some commands were stopped"
- RobertJSawyer
Could you please send me your settings.fdb file to our support mail?
- RobertJSawyer
I just sent the requested file to: fastkeys.info
if there's a better email address, please let me know.
All best wishes!
All best wishes!
Hi - I'm getting the same message. How was this issue resolved?
You can send us your settings.fdb file and we will check.
