Easy start menu creation?
nth
Post by nth » Jul 1st, ’16, 15:33
I'm wondering if there's a easier way to create a start menu?
Right now I'm having to add a new item and then browse to each executable program. Not too bad, but kind of slow.
Is there a way to possibly use drag and drop to build a start menu? That way I could open the Windows Start Menu folders and then just drag and drop the apps I want into the FastKeys start menu. I don't think that's possible right now, but would be cool if that could be done.
-nth-
Post by Marko » Jul 2nd, ’16, 12:08
The easiest way is to use a quick-add shortcut - default Ctrl-1. select a file in Windows Explorer and press Ctrl-1 to add it to FastKeys.
It works with many items, including files, folders, shortcuts, text, scripts etc. You can change the default in Preferences/Shortcuts.
nth
Post by nth » Jul 2nd, ’16, 18:12
Marko,
Exactly what I was looking for! Thanks!
