When I run this text expander it prompts for the client but not the Start or End date, any assistance would be most appreciated.
sudo /usr/openv/netbackup/bin/bplist -b -l -B -I -R 4 -t 15 -C %INPUT_Client% -s %SELECT_StartDate% -e %SELECT_EndDate% {/} {|} tr -d "{\}0" {|} awk '{{}print $4,$5,$6,$8{}}' {|} sed s{/}".~.*"{/}""{/} {|} sort -u {|} grep -iv {^}0
Thank you,
JGM
Select Date Field Does Not Appear
I checked and it works just fine for me. Double click on SELECT_Date fields to see if Type is set to Date.
