When defining the string names for text expanders, is it by design where the name cannot contain spaces?
When I named the string with spaces and ran it nothing happened. When I removed the spaces and ran it, it then it worked.
Thank you,
JGM
Text Expander String Name
Hi JGM, typically you would not use spaces within the abbreviation but it should work. I tried:
String: a b
Type: Send
Substitute aaaaa bbbbb
and it works as expected. However a suggestion will not pop-up when the "Display suggestions when you type" is enabled because Space resets a word recognition.
String: a b
Type: Send
