Open web address from one browser into another. Possible?
cadudesun
Post by cadudesun » Dec 1st, ’15, 22:22
My default browser is Chrome, but I sometimes I need to open in Firefox a website found in Chrome by manually copying/pasting from one browser to another.
Would Fastkeys provide a command that I would select the address in Chrome, then access the command in order the selected website would be load automatically in Firefox?
I use the following command to open any selected text in Google Search. What I am looking for is based on that principle, but I don't have idea how to handle the Chrome/Firefox scenario.
Send, ^{vk43} ;Ctrl C
Sleep 50
Run, http://www.google.com/search?q=%clipboard%
Post by Tom » Dec 1st, ’15, 23:28
The command below selects the address bar (Alt-D), copies URL to clipboard (Ctrl-C) and then runs Firefox with it:
Send !d
Send ^c
Sleep 50
Run, "C:\Program Files (x86)\Mozilla Firefox\firefox.exe" %Clipboard%
cadudesun
Post by cadudesun » Dec 2nd, ’15, 11:02
Thank you. It worked great!
