Hi Marko,
I really like the new features you introduced in this version: The clipboard manager AND the possibility to create shortcuts like "RButton & WheelDown" for example!
I am now ending my trial period and buy Fastkeys.
New features in version 2.11
Thanks, very much appreciated!
Great example of the shortcut, I would just do "~RButton & WheelDown" (add ~ sign) to keep the normal right-click functionality. Also, the advanced shortcuts shall be used carefully as the wrong syntax could cause unexpected behaviour. But if you know what you are doing there are no limits.
