Portable version
Ennovy
Post by Ennovy » Mar 18th, ’14, 09:16
I am evaluating the portable version and I found that it is not really stealth.
Found additional file installed.
Does FastKeys portable place more files or settings outside the FastKeys folder besides the file I mentioned above and does it write to the registry?
Thanks in advance for your support
Post by Marko » Mar 18th, ’14, 10:01
Agreed, it is not completely portable. It was released as a test few months ago with a goal to allow users using it on their work computers where normal installation would not be possible.
There are no other files installed and there are no registry entries.
Ennovy
Post by Ennovy » Mar 18th, ’14, 10:15
There are no other files installed and no registry entries.
Thanks Marko.
