mouse gesture question
Hi, is it possible to use a mouse gesture to make active a running application that is not currently active? (I have this running application called datadrawer that is not currently active. I would like, upon making the gesture, to make this application active.) Is this possible?
Hi Howard, of course. Select a gesture (or any other module), use Type=Command and put the following into the command field:
The window name is case sensitive so you might have to change it to your actual window name. For more information about this command, you can visit Autohotkey documentation at http://www.autohotkey.com.
WinActivate, datadrawer
