Open html with Chrome
Hy..
how do I open a local html with chrome?
I want to open a set of pages in chrome + html files in notepad.
Put like this:
file:///C:/index.html
C:/Users/index.html
The first line to open in Chrome and the second to open in Notepad, however, the two open in notepad!
What should I do to get the chrome on the front line?
Put like this:
C:/Users/index.html
To open files with non-default application just do like in the following examples - Type=Run:
Please check if your path to Chrome.exe is the same.
notepad C:/Users/index.html
C:\Program Files (x86)\Google\Chrome\Application\chrome.exe C:/Users/index.html
Hum.. very simple! but..
If the folder name has a space? Type:
c:/folder name/index.php
folder name = space in two names!
Edit: not accept %20 in space!
Could you give me your example of file and folder names you want to run?
C:\Program Files (x86)\Google\Chrome\Application\chrome.exe C:/Users/Bruno/Web Sites/Flash_html/GooSite/increate/increate/goosite/index.html/
Ok, I see, in this case you can put the file name in quotes, same as in WIndows:
C:\Program Files (x86)\Google\Chrome\Application\chrome.exe "C:/Users/Bruno/Web Sites/Flash_html/GooSite/increate/increate/goosite/index.html"
