Autocomplete wordlist file
Johan9
Post by Johan9 » Nov 22nd, ’13, 19:09
I like autocomplete function in your program very much. Is possible to use wordlist files with words of other languages? If yes, how to do it? Thank you and sorry for my bad english.
Post by Marko » Nov 23rd, ’13, 21:35
Hi Johan, yes, you can use any wordlist txt file. Just search the internet and you will see that there are many around. Make sure each word is in the separate line and save the file in UTF-8 or Unicode format.
Please let me know if you will experience any trouble.
