Loading Fastkeys
rachidg
Post by rachidg » Aug 29th, ’13, 12:28
Hi everyone
When I launch Fastkeys on Win 7 Pro, the message "Fastkeys Loading" stays on my screen and also when I try to launch the menu or the setting it doesn't work. Then I have to quit FK
Thanks by advance for your answer.
Rachid
Post by Marko » Aug 29th, ’13, 13:28
You must have troubles accessing internet. Please download and install the latest version (released today) and check if the issue persist. If you still experience problems, please send me an email and I'll try to help.
rachidg
Post by rachidg » Aug 29th, ’13, 15:33
Thanks Marko. It works fine now. After a while FK loaded (the auto download has been disabled)
Thanks!!
Post by Marko » Aug 29th, ’13, 15:36
I'm glad it's working fine now. Please check your firewall settings to allow menu icons download.
