Call of Duty
DutyMan
Post by DutyMan » Jul 17th, ’13, 13:16
Hi there, any useful shortcuts, cheats or fast fires for Call of Duty available?
Post by Marko » Jul 20th, ’13, 23:52
Of course, you can check Autohotkey forum for many ready scripts.
http://www.autohotkey.com/board/forum/59-gaming/
DutyMan
Post by DutyMan » Jul 27th, ’13, 22:53
Hi there Marko, I'm glad to find this app. Still need to study many rapid fires available. Do you know if using the script will significantly decrease my fps while playing?
Post by Marko » Aug 2nd, ’13, 08:54
Each Autohotkey script is different but in general they are using very small memory so it should not be a problem. Try them out and do some testing, I'm sure you will find the one that suits your needs.
