e-magic could not load...
bendonahower
Post by bendonahower » Jun 18th, ’13, 13:20
Upon start, a window popped up that e-magic could not load and after hitting 'ok' the rest of fastkeys finished loading, but the another window told me that all of my shortcuts would not operate. I haven't tried any remedies yet (I'm going to start with reinstalling) but wanted to at least let you know that that happened. I did recently run some cleaners, etc. that might have been overzealous...
Post by Marko » Jun 21st, ’13, 07:04
E-magic? I have no idea... FastKeys message that it can not operate the shortcuts typically means that one of the command is for some reason in conflict with another. Try disabling some of the shortcuts or commands to find the one which is creating a problem.
Please let me know if you are able to solve the issue. Thanks.
bendonahower
Post by bendonahower » Jul 21st, ’13, 03:06
Just saw this... I had forgotten all about it. The issue has been resolved, but I forgot how at this point.
