Can't make my script work ONLY in a specific window
Drakemoor
Post by Drakemoor » Jun 5th, ’23, 23:51
I'm trying to make Fastkeys insert two Enter when I hit enter once and one Enter on Shift+Enter, only when typing in the Obsidian app. Unfortunately, it does it in all apps, regardless of the code I use. Here are two examples:
#IfWinActive ahk_exe Obsidian.exe
::Enter::
Send {Enter 2}
::^Enter::
Send {Enter}
#IfWinActive
Here is a second one:
::Enter::
Send, {ENTER}{ENTER}
::^Enter::
Send, {ENTER}
I've tried putting the name of the app in the window option, but that also doesn't work.
Please help.
Post by Marko » Jun 6th, ’23, 07:07
You should use a name of the window or ahk_class to identify the window. Use Window Information Tool to get this info - Tools/Window Information.
Also, you are using the shortcut syntax incorrectly. It should be
Enter::
instead of
::Enter::
Drakemoor
Post by Drakemoor » Jun 6th, ’23, 13:51
Thank you! That worked.
