Where are the presets?
bendonahower
Post by bendonahower » May 19th, ’13, 22:00
How do you get to the 'select a preset' window?
bendonahower
Post by bendonahower » May 19th, ’13, 22:07
Ding! Turns out there is a little 'p' past the 'type' field when you are creating a shortcut, etc.
Post by Marko » May 19th, ’13, 23:31
Hi Ben,
yes, a little "P" is probably the most powerful button in FastKeys. Presets shown are dependent on a command Type. You can see all presets by choosing "Command" type. Try them out!
