Insert Link
ArFarrah
Post by ArFarrah » May 8th, ’23, 04:22
how to insert Link? What code should I Use? Please see the image https://prnt.sc/jJyNCEb8TMH1
Thank you
Post by Tom » May 9th, ’23, 12:13
Create a shortcut to simulate Ctrl+K?
{Ctrl Down}k{Ctrl Up}
ArFarrah
Post by ArFarrah » May 10th, ’23, 02:56
Thanx!
I used this code using this key ALT+K, Ctrl+K in my case wont work.
{Ctrl Down}{Shift Down}{Left}{Shift Up}{Ctrl Up}{Ctrl Down}k{Ctrl Up}
