hi!
I have a .fdb that makes heavy use of Start Menus and Selection Tables.
I can export it just fine, and in fact a folder with the Tables is created when doing so.
When I open the shared file in the secondary computer I want to use it on, all Selection Table entries point to the address in my main computer, effectively making the the database not work.
Is there a way around this?
Export function and Selection Tables
You would need to adjust the paths manually.
I recommend you keeping the tables in the default folder, this way it should work on all computers.
