open folder in Start Menu?
othree
Post by othree » Feb 15th, ’23, 14:57
how can I open a folder in my Start Menu? For example "d:\data\2023"
I found out how to open files, but not folders.
Thanks for your help!
Cheers,
O
Post by Marko » Feb 15th, ’23, 20:57
Type: Run
d:\data\2023
othree
Post by othree » Feb 16th, ’23, 10:00
huh .... easiest solution :) Thanks, works like a charm! :)
