Weird behaviour on Win 11 and Fastkeys 5
Mojito
Post by Mojito » Feb 9th, ’23, 14:24
I just recently upgraded to windows 11 and as well as moved to Fastkeys 5 (was on win 10 and fastkeys 4 prior)
I made sure to launch the Fastkeys as administrator as well
But I'm noticing some issues with some applications like in Affinity Designer, the software's Control+1 (zoom @ 100%) doesnt work anymore. When I close Fastkeys, it works fine. And the even weirder part is I dont even have any shortcuts set for CONTROL+1
Is v5 buggy? Should I go back to v4?
Post by Marko » Feb 9th, ’23, 19:55
Change the Quick Add shortcut in Preferences/General/Shortcuts to something else or remove it.
Mojito
Post by Mojito » Feb 10th, ’23, 11:54
Marko wrote: Feb 9th, ’23, 19:55 Change the Quick Add shortcut in Preferences/General/Shortcuts to something else or remove it.
oh wow i didnt see that sneaky one
