Is there any way to '#include' a lib from an external directory?
Oblomov
Post by Oblomov » Jan 30th, ’23, 14:38
(Inside of a command) Such as from 'C:\Program Files\AutoHotkey\lib'... I've tried every combination :(
Post by Tom » Jan 31st, ’23, 07:23
Try adding the #Include command into the Tools/Startup code and let me know how it works.
Oblomov
Post by Oblomov » Jan 31st, ’23, 08:48
Tom wrote: Jan 31st, ’23, 07:23 Try adding the #Include command into the Tools/Startup code and let me know how it works.
Hm, is that something from one of the new versions? I'm still on 4.29 if anything... Doesn't seem like you can add a lib somewhere inside of the 'Tools' tab if anything.
Searched for 'lib' and 'library' inside of:
https://www.fastkeysautomation.com/docu ... index.html
also
Post by Marko » Jan 31st, ’23, 14:14
This feature was introduced in version 5.09. You cannot do this with the old version.
Oblomov
Post by Oblomov » Jan 31st, ’23, 14:37
Marko wrote: Jan 31st, ’23, 14:14 This feature was introduced in version 5.09. You cannot do this with the old version.
I see... yes. I've run into a number of fundamental issues with the new iteration of FK (viewtopic.php?f=4&t=1747&p=5767#p5767, e.g. 'Couldn't quite 'isolate' the 'Run' type commands through the 'Sort' function by the way 😞'), so I think I'll keep to the 'good' old 4.29 yet...
I'm guessing the only way to include a library for something like 4.29, would thus be the way shown by the OP of:
viewtopic.php?f=4&t=448&p=1803&hilit=lib#p1803 ?
Oblomov
Post by Oblomov » Feb 7th, ’23, 21:54
Err...
