[Solved]v5.10 Issue
mragtronx8
Post by mragtronx8 » Dec 30th, ’22, 07:03
Hi Marko,
when i updated to v5.10, am sometimes having to reload Fastkeys several times; due to a bug.
Am using win 8.1 x64 - rhino 3d v7
in v5.09 when i executed a start menu send command
trim{enter} [in v5.09 = everything works properly]
in v5.10 = enter is being executed more than once [in more than several other command types].
as if the command/s are trigger directly or :?:
my temp solution is to continuously reload fastkeys :!:
this is for your kind review and action.
Best Regards.
Happy Holidays
Post by Marko » Dec 30th, ’22, 09:48
I tested it and see no issue. Can you please contact our support mail and attach the fdb file?
mragtronx8
Post by mragtronx8 » Dec 30th, ’22, 10:05
email sent with fdb
