Shortcut for just one application?
RadioGregg
Post by RadioGregg » Sep 26th, ’22, 00:21
For one particular application I use, I would like to have the right arrow be a trigger for Alt+Right and the left arrow be Alt+Left.
I thought I could just make a shortcut for that [{Alt Down}{Right}{Alt Up}] and then specify the name of the application in the Window field.
Well, I get the desired result in the one application, but now the left and right keys don't work at all in other applications.
Is there a way to get the shortcut to work in one application but not change the behavior of the left and right keys in any other application?
Many thanks, Gregg
Post by Marko » Sep 27th, ’22, 19:43
That should work. You probably have the Window field set wrongly. I suggest you send the screenshots of your settings to our support mail to see where the problem is.
