Is there a way to have a variable in a shortcut command? Basically I sometimes need to run a cycle 2, 3, or 4 times across multiple shortcut commands and I'd like to just be able to set a variable and have all the commands use that variable for a loop cycle.
This is a series of keyboard commands, so it has to be a shortcut and not a text expander.
Or if you have a better idea?
Variables in Shortcuts?
Not sure I understand what you mean. You could set User variables and reuse them in any of the commands.
