Shortcuts for a specific software
Hi-new to this forum.
I have a software program, DXO Photolab 5, for editing and managing photos.
I need to cull faster than DXO Photolab 5 currently provides. To delete a photo you currently have to hold control plus 9. Will Fastleus allow me to modify this to Z for deleting photos?
I sometimes can have 1500 photos in one photoshoot and the control plus 9 is not efficient.
Any input appreciated.
SM
SM
Yes, set a shortcut:
Shortcut: Z
Command:
Window: DXO (or use Window Information Tool to find the window name or class of the application).
Shortcut: Z
Command:
{Control down}9{Control up}
Thank you very much!!
What does this mean? Window: DXO (or use Window Information Tool to find the window name or class of the application).??
Thanks again.
SM
Thanks again.
SM
Select "More options" to access Window settings - here you can specify windows in which your shortcut will be active.
https://fastkeysautomation.com/document ... tcuts.html
I started the Z command to run with DxO photolab 5 in order to delete photos faster.
I followed what I thought was the correct procedure but a get the following message:
Error: parameter X one invalid.
Specifically: down)9[control up)
Line#
004: Return
005: Return
007: (
007: Control,Down)9(control up)
The program will exit.
How can you post a screenshot with a post?
Thank you have much.
SM
Line#
004: Return
005: Return
007: (
SM
You should copy the code exactly
