Apps runnning as Admin thru FASTKEYS
mragtronx8
Post by mragtronx8 » Jun 16th, ’22, 19:55
when am launching apps thru FastKeys [gesture / text expander / start menu], they are always running as administrator [even though they are not set to run as admin in windows].
Is there a way to control apps running from FastKeys to "run as admin" or "run as non-admin"
Best Regards,
Mragon
Post by Marko » Jun 16th, ’22, 21:17
Do you have Run as administrator option enabled in Preferences/General?
mragtronx8
Post by mragtronx8 » Jun 17th, ’22, 09:15
hi Marko,
Fastkeys = run as admin is ENABLED
thx - issued solved when i switched it off.
