Importing only "auto complete" option
marcelolima
Post by marcelolima » Jun 10th, ’22, 00:50
Hello, Team FastKeys.
I would like to transfer to another computer (another *.fdb database) only the "auto complete" part.
Would it be possible, without importing/copying the entire *.fdb file?
I know I could copy the file to the *.fdb file or just import. But this option would unconfigure a part that I don't want to modify, like the "start menu", for example.
Thank you very much.
Tchelo.
Post by Marko » Jun 11th, ’22, 07:48
One way would be to create a new fdb file by using File/Save as..., delete all unwanted items and then use File/Append to import the file.
