Excel Import
Marty123
Post by Marty123 » Jun 1st, ’22, 13:16
Hi good people at Fastkeys,
I have some missing fields when I import excel file to use as phrase file under text expander. that said, I can always manually go in to add those missing parameters in the phrase file (it is always some ''substitute'' fields that's missing and not "abbreviation") but when i import on the regular, it can be time consuming. I wonder if the bug is noted and going to be fixed in the next updates.
Thanks.
Post by Marko » Jun 1st, ’22, 21:16
Thanks for reporting this. Could you please send us the example of the specific Excel file which is not imported correctly? Please use our support mail. Thanks.
Marty123
Post by Marty123 » Jun 4th, ’22, 12:59
Hi Marko, thank you. I've reached out and you've replied. I tried your solution and it works. Thanks.
