In Preferences/Functions/Volume the option to control the volume with mouse wheel on right screen edge is active.
However this only works on my second monitor.
Is this a bug or is there another setting I have missed
Thanks in advance for your support
Peter
Settings volume control with mouse wheel
It works on the far right edge of the monitor setup. If monitors are not right aligned, it will only work on right one. What's your monitor setup?
I use a laptop and my second screen is above my laptop screen
Probably monitors have a different resolution. The volume will function on the far right pixle edge, this is by design.
