Clipboard Manager hack???
RadioGregg
Post by RadioGregg » Apr 24th, ’22, 18:03
Hi...
If I right click the FastKeys icon on my taskbar I can then click Clipboard Manager and I get a window that stays open - that's what I want, a Clipboard Manager that stays open.
If I go into Settings and set a shortcut for Clipboard Manager, I get a thinner Clipboard Manager popup that disappears after I click something on the list or just click away.
Is there a way to create a shortcut for the persistent Clipboard Manager that stays open OR my preference would be to make the thinner Clipboard Manager stay open all the time?
Many thanks, Gregg
Post by Marko » Apr 26th, ’22, 06:07
Currently the only way to open the floating clipboard manager is to select if from the menu. We may add a separate shortcut in one of the next updates.
RadioGregg
Post by RadioGregg » Apr 26th, ’22, 09:31
That would be awesome.
I am a little confused by terminology.
Which is the floating clipboard manager...the one that stays open all the time?
FWIW, I control a lot of functions on my computer with my voice using TalonVoice...going to try to figure out if I can open the clipboard manager with my voice...I will keep you posted.
Thanks, Gregg
Post by Marko » Apr 26th, ’22, 19:44
Yes, I was referring to “always on top” clipboard manager.
