Hi Support Team,
it would be very helpful if you could explain by example what is meant by this:
"How to use selection input fields for conditional logic only and not output the selected value?
Use underscore "_" prefix in the variable name (like "_MyVar") not to output the text."
Best regards,
u_v
In the recent FastKeys versions, there is a "No output" setting in Manual Text Input and Selection Form macros.
