Hello.
I would like to use autocomplete in Google Docs (Chrome and Firefox). It works perfectly if I don't use "rich text".
The problem is that if I use text in bold or italics, for example, in the "rich text" field, the task does not deliver these highlighted words.
What should I do?
Thank you so much.
Have a great week!
Google Docs
- marcelolima
In this case, try using a HTML mode. You can use an online service like this
https://html-online.com/editor/
and paste the created code to FastKeys.
- marcelolima
Thanks for your reply, Marko.
In my case, I use Google Docs because my work is on the Google platform. This is just one of the reasons and less important.
Also the text typed is always automatically saved in my Google account.
As your suggestion is to edit in an online service and paste, I will keep editing in LibreOffice and pasting the text in the service of my job.
The incompatibility with Google Docs didn't avoid me from acquiring the program license.
Thanks again!
FK is amazing. I really recommend the application.
Thanks again!
