Need advice about one problem. Thanks
Formingus
Post by Formingus » Mar 11th, ’22, 13:21
I am using one method to execute some apps. But because they are too deep into the directory app name is too long. Is there a way to execute the app but on the visible part to be only the APP name, not the full path? Thanks
10 sec video, explained what i am trying to do
https://youtu.be/FvCs2cTIAdM
Post by Marko » Mar 12th, ’22, 09:54
To improve visibility, add a description prefix to multiple selections. In this case only description will appear on a popup window. The default description separator is "::" which can be changed in Preferences > Text Expander.
Example (Type: Run):
Firefox:: C:\Program Files (x86)\Mozilla Firefox\Firefox.exe
/MyFolder:: D:\MyFolder
/FastKeys webpage:: http://www.fastkeysautomation.com/
https://fastkeysautomation.com/documentation5/Run.html
Formingus
Post by Formingus » Mar 12th, ’22, 18:24
Marko wrote: Mar 12th, ’22, 09:54 To improve visibility, add a description prefix to multiple selections. In this case only description will appear on a popup window. The default description separator is "::" which can be changed in Preferences > Text Expander.
Yes, Name is displayed but the application won't run! What i am doing wrong?
This is how code looks like
Dirsync:: D:\Sherif\Software\SyMenu\ProgramFiles\SPSSuite\SyMenuSuite\Mine\DirSyncPro-1.53-Windows\DirSyncPro.exe
/Clipdiary:: D:\Sherif\Software\SyMenu\ProgramFiles\SPSSuite\SyMenuSuite\Mine\clipdiary_portable\clipdiary-portable.exe
Post by Marko » Mar 12th, ’22, 18:50
Check if the Type is set to "Run" and paths are correct.
Right click and enable Insert mode. Then use "Open" icon to select files.
Formingus
Post by Formingus » Mar 13th, ’22, 16:00
Marko wrote: Mar 12th, ’22, 18:50 Check if the Type is set to "Run" and paths are correct.
Yes, it is set to RUN and the path is correct because it will run if i remove "Firefox::" in front of the software path.
Idea was to show only the name, not the full path.
Post by Marko » Mar 13th, ’22, 16:14
It should work. Which FastKeys version are you using? Could you try one of the standard windows files? Use Open icon to open the path. If this doesn’t work please contact our support.
Formingus
Post by Formingus » Mar 14th, ’22, 18:55
Marko wrote: Mar 13th, ’22, 16:14 It should work. Which FastKeys version are you using? Could you try one of the standard windows files? Use Open icon to open the path. If this doesn’t work please contact our support.
No, it not work , probably coz i use portable version
Post by Marko » Mar 15th, ’22, 22:16
There should be no difference. Please contact our support.
Formingus
Post by Formingus » Mar 17th, ’22, 12:24
Marko wrote: Mar 15th, ’22, 22:16 There should be no difference. Please contact our support.
I Just try installer instead of portable and it works fine
After this i try Portable and work too - Dunno, maybe some mine mistake
Thaks a lot for support
