Text Expander Separate 'Files'
tbgb50
Post by tbgb50 » Mar 2nd, ’22, 13:57
I am using the trial version to make a decision so I can replace Breevy but am getting lost in the weeds.
I want to have multiple, separate phrase folders that are active one at a time since I use the same abbreviations but with different text. Is this possible?
So far I have setup separate phrase files but when I add an abbreviation it is limited to the text i.e. there is no option for input fields. Is this a restriction?
I did create text expansions with the input fields but they are under Phrase files as a standalone item that apparently cannot be moved to one of my phrase folders. Am I missing something?
Thanks for any help.
Post by Tom » Mar 2nd, ’22, 21:45
Phrase files are intended for simple text expansions without macros. You can create separate settings and load them when needed. Use File/Save as to save the file under a different name and File/Open to open file.
tbgb50
Post by tbgb50 » Mar 3rd, ’22, 14:14
Hello Tom,
Thanks for your help. This is exactly what I needed to know.
- Howard
