Elermino
Post
by Elermino » Jan 12th, ’22, 12:35
This script is used to search Google as text if what is selected is a text and as a URL if what is selected is a URL, in my case this is activated by drawing a gesture. I have been told that the problem may be that the script requires variable initialization to work in FastKeys, but I don't know how to do that
This is the code:
port:=Clipboard
Send, ^c ;Ctrl C
Sleep, 100
Run, % (clip := Trim(clipboard)) ~= "^(https?://)?([\w\d]([\w\d]|(-[\w\d]))*\.)+\w+(/\S*)?$"
? (clip ~= "^(https?://|www\.)" ? "" : "http://") . clip
: "https://www.google.com/search?q=" . fix(clip)
Return
fix(url)
RegExMatch(url, "^(https?://)?(.+?)(/)?$", part)
Loop, Parse, part2
text .= A_LoopField ~= "[$&+,:;@""<>`%{}|\\^~[\] `]" ? Format("%{:X}", Asc(A_LoopField)) : A_LoopField
Return part1 text part3
Clipboard := port
And this is the error:
https://imgur.com/a/ZMyow1h
Post
by Marko » Jan 17th, ’22, 09:49
This is a warning, not an error. Probably you have added another script which includes a #Warn statement - remove it.
Alternatively you can add a
line just before a Loop, parse statement.
Elermino
Post
by Elermino » Jan 19th, ’22, 17:50
Marko wrote: ↑Jan 17th, ’22, 09:49
Solved. Thanks
Post
by Marko » Jan 20th, ’22, 22:39
Great, was it a #Warn statement?
Elermino
Post
by Elermino » Jan 25th, ’22, 14:52
Marko wrote: ↑Jan 20th, ’22, 22:39
It seems to me that yes, since after clicking "ok" in the box that appeared, the order was already executed. Why is writing code different in FastKeys than writing an AutoHotkey script?
Post
by Marko » Jan 25th, ’22, 18:24
There is no difference. The only thing is that other command codes may interfere.
