Text expander not working after left curly brace
eselick
Post by eselick » Jan 3rd, ’22, 21:21
Hi - I'm trying to set up a text expander for the following string which when typed in the Windows Explorer address bar brings up the recent folders dialog;
shell:::{22877a6d-37a1-461a-91b0-dbda5aaebc99}
Do I need to escape the ( char?
Thanks
Post by Marko » Jan 4th, ’22, 23:02
Check the Preferences/Text Expander - if you have “Enable modifiers” option enabled then you need to escape the curly brackets like this
shell:::{{}22877a6d-37a1-461a-91b0-dbda5aaebc99{}}
See special characters section:
https://fastkeysautomation.com/documentation5/Send.html
