Macro on Windows Starts?
N7Commander
Post by N7Commander » Dec 31st, ’21, 21:57
I have been searching in the forum for a solution or idea, but I couldn't find anything related to my problem, because of this I am creating a post about this.
I created a macro and organized some things in my 3 monitors and windows adjustments, but I want to run the macro on Windows Start, I have a fast M.2, and I have added 10 seconds to the macro runs after the hotkey is pressing, is it possible to change the hotkey to some kind of script or pre-define reserved word in the fastkeys to make it run the macro after the fastkeys runs on startup?
How can I run the macro on Windows Start, Fastkeys already are loading on startup.
Post by Tom » Jan 1st, ’22, 20:42
Create a Start menu item and select Run on Startup option - this will run the macro each time FastKeys starts.
N7Commander
Post by N7Commander » Jan 1st, ’22, 22:03
Ty, this menu was the only memu on the app that I was made hidden, now I enable it and set only the macro I already recorded.
