How is possible to not have copy past options or i can't find it?
Due to the text expander, if the text is too long it will not past but it will write part by part and make PC hang and some other bugs!!! Checked - unchecked send Raw text, still same. Any idea?
Tha ks in Advances
How is possible to not have copy past options ?
Do you mean using clipboard for expanding the text? You can find this setting under the Preferences/Text Expander/Advanced - Use clipboard if text length...
Thanks, i try that option but when i use text expander ex
ttt = some very long text ex:3000 char and more then it will write sentence by sentence while displaying some quadrant on the notepad.
Is there a way to make it like copy past , Thanks ...
https://youtu.be/3uhrgFKnPcg >>>>>> Video explain everything - Cant hyperlink or upload here video, its link of youtube
I tried and it works on our computers. How long is the text?
If the issue persists please contact our support mail.
