Find and replace characters in the macro database
rickchapman53
Post by rickchapman53 » Dec 22nd, ’21, 00:53
I'd like to know if you can run a find and replace operation on the FK text expander database to update the abr string?
Post by Marko » Dec 22nd, ’21, 20:18
You could open the settings file in any text editor and make the changes.
rickchapman53
Post by rickchapman53 » Dec 28th, ’21, 18:18
Thank you very much. You might consider adding this note the help file.
Oblomov
Post by Oblomov » Jul 5th, ’22, 16:51
Marko wrote: Dec 22nd, ’21, 20:18 You could open the settings file in any text editor and make the changes.
Oh, that sounds wonderful!
So I'm guessing one can basically edit all instances of a specific 'MouseMove' (1740 in this case)? If so, would one first need to shut down FK, or just restart it after replacing the said, specific 'MouseMove' or what have you?
Post by Marko » Jul 5th, ’22, 19:53
Just reload FastKeys after making changes.
Oblomov
Post by Oblomov » Jul 5th, ’22, 20:05
Marko wrote: Jul 5th, ’22, 19:53 Just reload FastKeys after making changes.
Gotcha, thanks!
