Installer vs Portable Version difference!
Formingus
Post by Formingus » Dec 7th, ’21, 10:44
With FastKeys Installer - Scrolling Mouse t right of the screen with Raise or lower volume
With Portable Version will not, even i try with backup restore settings from installer to portable
Why it does not work ? Any way to do this at portable?
Thanks
Post by Marko » Dec 7th, ’21, 22:31
There should be no difference. You need to enable the volume control feature in Preferences/Functions.
Formingus
Post by Formingus » Dec 8th, ’21, 16:41
Marko wrote: Dec 7th, ’21, 22:31 There should be no difference. You need to enable the volume control feature in Preferences/Functions.
Yes, you do have right, it was unchecked, but what's confused me was because I exported and imported the setting from Installer ... any way probably some mine mistake. Thanks
