Fastkeys; text expander; Send text in utf - 8 (fast keys support ansi) to software based on utf - 8
marko1991
Post by marko1991 » Dec 5th, ’21, 10:30
Hello
How i change text coding from ansi to utf-8 in fastkeys text expender . The problem appears when adding soecial characters which are different codet in ansi and utf - 8. Special characters are not inserted correcty to utf environment from text expender (ansi). I thank you in adwance for any answer give.
Post by Marko » Dec 5th, ’21, 10:50
FastKeys supports UTF-8, just copy the characters to the command field.
marko1991
Post by marko1991 » Dec 5th, ’21, 12:48
I already have characters copyed, but when input fron fast keys text extender is made no character appear in utf-8 supported software (only sign ? appears in utf-8 software).
marko1991
Post by marko1991 » Dec 5th, ’21, 18:01
Greetings
More information is given in the video bellow. Marko please give me a working solution. Thank you.
Video
https://unichemsi-my.sharepoint.com/:v: ... w?e=AcWEAC
Characters which dont work. Other in the movie work.
marko1991
Post by marko1991 » Dec 13th, ’21, 19:25
Any answer?
Post by Marko » Dec 13th, ’21, 22:19
Sorry, I don’t have a solution. It works for me in all other applications. It could be that SAP uses specific fonts.
