How to open new tab in Directory Opus?
HerbHert
Post by HerbHert » Nov 6th, ’21, 18:09
With the start menu each folder run opens a new instance of directory opus.
Quick Access Popup opens instead a new tab in Directory Opus. Is it possible with Fastkeys too?
Thank you for hints!
Post by Marko » Nov 7th, ’21, 18:15
Running software paths from FastKeys works the same as using Command prompt (Cmd). Please check command line switches that would allow this in Directory Opus.
HerbHert
Post by HerbHert » Nov 9th, ’21, 16:41
Thank you!
