Prompt for URL variable, then go to URL+variable
jvroom
Post by jvroom » Nov 3rd, ’21, 14:05
Hi All,
I'm seeking assistance with the following...
Create a start menu item that when clicked or triggered by keyboard shortcut will...
Prompt me for a variable, say "DocNum" (always a 5 digit number) that will be appended to the end of a fixed/known partial URL
Go to Firefox Browser (Typically already open)
Go to/or open a New Tab
Enter the predefined partial URL in the address box (say "https://partialURL"
Append the above "DocNum" variable to the end of the PartialURL
Go to the complete (concatenated) URL (https://partialURL/DocNum
Thanks for any assistance you can offer.
Post by Marko » Nov 3rd, ’21, 20:19
This should give you the idea (Type: Command).
InputBox, DocNum, Input, Enter 5 digit number, , 200, 120
Run, https://partialURL/%DocNum%
