how make dot every 4 character number
stevenwi87
Post by stevenwi87 » Oct 16th, ’21, 06:06
have script how make every 4 character number have dot
example
081234567890 to 0812.3456.7890
Post by Tom » Oct 16th, ’21, 21:26
Create a shortcut (Type=Command) - this script will replace the selected string with a formatted one.
send, ^c
sleep 200
string:=""
loop, parse, clipboard
	string:=string A_LoopField (((Mod(A_Index, 4) = 0) && (A_Index != StrLen(clipboard))) ? "." : "" )
sendinput % string
stevenwi87
Post by stevenwi87 » Oct 17th, ’21, 02:26
thank you for help tom your awesome
