Saving Start Menus Menu shortcuts
jcfastkeys
Post by jcfastkeys » Sep 11th, ’21, 17:05
When you change the Menu Shortcut for a Start Menu, how do you save it?
Post by Marko » Sep 13th, ’21, 19:05
To change the Start menu shortcut, go to Preferences/Start Menu, select the Menu shortcut field and press the shortcut on your keyboard.
Select OK button to save the Preferences.
