gbop515
Post
by gbop515 » Sep 7th, ’21, 04:09
For the text expander, I have a long list of choices (62 to be exact). For example:
one
/two
/three
/three
/sixty-two
The laptop I use is 13 inches in size. All 62 choices are not visible when popup opens.
Would it be possible to display all choices in columns or add a scroll bar for such a long list of choices?
Thank you so much!
Post
by Marko » Sep 7th, ’21, 21:22
For longer selections I suggest you use a Selection Form macro which will show the scroll bar or break suggestions into columns (Preferences/Text Expander/Advanced).
