Opening Multiple MSWord Documents Disables Word Macros
=Jagz=
Post by =Jagz= » Sep 4th, ’21, 18:24
I created a menu item to open multiple Word documents that used to work. Recently it caused Word to give the error message
"The macros in this project are disabled. Please refer to the online help or documentation of the host application to determine how to enable macros."
I originally got around it by adding a pause to the script, but now this no longer works.
I'm using MS Word 2016
Here's an example of the script using Open:
C:\Users\xxx\OneDrive\Documents\Document1.docx
{10000}
C:\Users\xxx\OneDrive\Documents\Document2.docx
Got any ideas to fix this?
Post by Marko » Sep 4th, ’21, 19:22
Pause will not work in Open (or Run).
You could try Type: Command
Run, C:\Users\xxx\OneDrive\Documents\Document1.docx
Sleep, 1000
Run, C:\Users\xxx\OneDrive\Documents\Document2.docx
